RasterLayer Visibility
1414
01-01-2018 10:46 PM
santiagomonedero
Hi, I am using rumtime v100.2.0 to load a rasterLayer on a Scene from a local *png. This works fine, but the raster layer disappears when reaching a given scale (zomming out). Is there a way to force the raster layer to be always visible? (I have tried adjusting rendering options and setting min/max scale to the scene and the layers without success)
thank you
dotMorten_esri
Esri Notable Contributor
Currently this is a known limitation of the raster layer (the limit is there's a limit to how much it'll down-sample).
We are however aware that this is a rather annoying limitation, and working on improving this in a future update.
An alternative is have pre-generated pyramid data, which can extend the visible range. You can for instance use Pro or ArcGIS Desktop to generate the pyramid data (yes it's also on our list to be able to generate pyramids with the runtime ).
