Query Feature Service and Rest API
4398
01-01-2018 08:50 AM
ViktoriaMagnis
I am trying to get the max(date) from a feature service using the rest api.
The where clause I am using is
SellDate =(select max(SellDate) from Buncombe_County_Property_Sales_Data)
But I keep getting 'where' parameter is invalid.
https://services6.arcgis.com/VLA0ImJ33zhtGEaP/ArcGIS/rest/services/Buncombe_County_Property_Sales_Da...
Vicki
JakeSkinner
Esri Esteemed Contributor
Hi Vicki,
ArcGIS Online only allows certain standardized queries:
Standardized SQL functions in ArcGIS Online—ArcGIS Online Help | ArcGIS
Subqueries as a where clause, for example, POP_2010 = (SELECT min(POP_2010) FROM counties, are not supported
You can accomplish what you're looking for Python, though.  Here is an example:
import urllib, urllib2, json, datetime, time
queryURL = 'https://services6.arcgis.com/VLA0ImJ33zhtGEaP/ArcGIS/rest/services/Buncombe_County_Property_Sales_Da...'
params = {'f': 'json', 'where': '1=1', 'outFields': '*', 'returnIdsOnly': 'true'}
req = urllib2.Request(queryURL, urllib.urlencode(params))
response = urllib2.urlopen(req)
ids = json.load(response)
minId = ids['objectIds'][0]
maxId = ids['objectIds'][-1]
x = minId
while x < maxId:
    y = x + 1000
    if y > maxId:
        y == maxId + 1
    where = 'FID >= ' + str(x) + ' AND FID < ' + str(y)
    params = {'f': 'json', 'where': where, 'outFields': '*'}
    data = json.load(response)
    dateList = []
    for data in data['features']:
        dateList.append(data['attributes']['SellDate'])
    x += 1000
    y += 1000
dateList.sort()
maxDate = str(dateList[-1])[0:10]
print(time.strftime(datetime.datetime.fromtimestamp(int(maxDate)).strftime('%c')))
RandyBurton
Are you using AGOL or your own server/service?  Are you using an HTML form, or are you using another method for your query?  In the meantime, I would suggest the following:
"where" : "1=1",
"outFields" : "*",
"orderByFields" : "SellDate DESC",
"resultRecordCount" : "1"‍‍‍‍
