query widget customization turn operational layers off when running a query
2090
12-28-2017 04:02 PM
Anish_Adhikari
I just configured the query widget for my application and it works well for the most part. However it would be great if when I run the query, my existing operational layers would automatically be disabled with query results layer as only visible layer.  Similarly I want the operational layer to be re-enabled when I click on remove the result link or close the widget.
I tried looking into query widgets code but not sure where the click events are buried.
Has anyone got any ideas about this?
RobertScheitlin__GISP
Anish,
   Here are the changes to the Query Widget.js (all additional code is added to the begging of each function indicated):
      postCreate:function(){
        this.mapObj = {
          layers: {}
      onClose:function(){
        //Use this to restore the layers visiblity state
        var layerOptions = this.mapObj.layers;
        this.layerInfosObj.restoreState({
          layerOptions: layerOptions || null
      //start to query
      _onBtnApplyClicked:function(currentAttrs){
        if (this.layerInfosObj && this.layerInfosObj.traversal) {
          this.layerInfosObj.traversal(lang.hitch(this, function(layerInfo) {
            this.mapObj.layers[layerInfo.id] = {
              visible: layerInfo.isVisible()
        //Now turn then off
            if(layerInfo.isVisible()){
              layerInfo.setTopLayerVisible(false);
      removeSingleQueryResult: function(singleQueryResult){
Anish,
        this.mapObj = {
          layers: {}
      onClose:function(){
      //start to query
        //Now turn then off
Anish_Adhikari
Thanks Robert. I really appreciate it.
