how do i use values from a multiple value parameter into a function
5149
7
12-27-2017 11:09 AM
stashavint
I want to allow the user to choose several value from a list of values then later i want to use these values to iterate through a raster data set. But very time i keep getting errors saying the data set is not correct. My code is here:
import arcpy,os
inputraster = arcpy.GetParameterAsText(0)
sea_level = arcpy.GetParameterAsText(1)
fc = arcpy.GetParameterAsText(2)
clipraster = arcpy.GetParameterAsText
valuelist = [x.strip() for x in sea_level.split(";")]
for value in valuelist:
        arcpy.Clip_management(inputraster,"#",clipraster,fc,"#","ClippingGeometry","MAINTAIN_EXTENT")
        clip_raster = arcpy.Raster(clipraster)
        floodedarea = os.path.join(outputfolder + "floods" + str(value))
        areasbelow = clip_raster <= value
        areasbelow.save(floodedarea)
        arcpy.AddMessage(areasbelow)‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
a multivalue parameter is often returned as a semi-colon delimited string as you have shown, however, I suspect you are only getting layer names and not paths to files which may be what is needed.
Perhaps you could throw in a few print/arcpy.AddMessage lines in so that you get some output from the tool to examine
XanderBakker
Esri Esteemed Contributor
Your value is a string. You will need to convert it to make it numerical by using int or float.
another argument for using sys.argv instead...
stashavint
which variable do i change to int or float is it the valuelist or the value? and I am confused on how to do that
XanderBakker
In case the values are integers you can do this:
valuelist = [int(x.strip()) for x in sea_level.split(";")]
XanderBakker
Remember when you obtain a parameter with GetParameterAsText you get it as text, when you use GetParameter you will directly have a list of numeric values. To explain this a little more, please see the example below:
In my tool I collect a list of values:
The script below contains this:
def main():
    import arcpy
    sea_level = arcpy.GetParameterAsText(0)
    arcpy.AddMessage("\nGetParameterAsText(0)")
    arcpy.AddMessage("sea_level={0}".format(sea_level))
    arcpy.AddMessage("type={0}".format(type(sea_level)))
    lst_sea_level = sea_level.split(";")
    arcpy.AddMessage("lst_sea_level={0}".format(lst_sea_level))
    arcpy.AddMessage("type of first element={0}".format(type(lst_sea_level[0])))
    lst_values = [int(v) for v in lst_sea_level]
    arcpy.AddMessage("lst_values={0}".format(lst_values))
    arcpy.AddMessage("type of first element={0}".format(type(lst_values[0])))
    lst_sea_level = arcpy.GetParameter(0)
    arcpy.AddMessage("\nGetParameter(0)")
if __name__ == '__main__':
    main()
In the first part it reads the parameter as text and you can see how it is processed to get a list of values. In the second part starting on line 19, I read the same parameter but now directly as a list without converting it to string. The result is this:
In your case it will be much easier to use GetParameter then using GetParameterAsText.
stashavint
Thanks let me put in my codes and i will tell you the output
