Remove part of image url for ArcGIS Online Popup
1374
7
12-22-2017 12:03 PM
BrandonPrice
Is it possible to remove part of the url I want to use to show photos in a popup through the ArcGIS Online image configuration console? I found a link that made me think this might be possible here: Show attached images inside popup with ArcGIS Online? - Geographic Information Systems Stack Exchang.... Any suggestions?
Brandon
https://community.esri.com/community/gis/web-gis/web-appbuilder?sr=search&searchId=632f7fb4-464e-424...
@arcgis
XanderBakker
Esri Esteemed Contributor
Not sure what you mean with remove part of the URL. Can you give an example?
There is a tool that might be interesting to look at: https://community.esri.com/docs/DOC-7445
XanderBakker
BrandonPrice
I am using someone else's layer in my webmap: http://www.dot.ca.gov/hq/env/gis/stormwater/sdsi/d7/photos/dp/110_s_22_12966_dis_34_0358_118_2749/in...
if I remove the last 10 characters so it reads: http://www.dot.ca.gov/hq/env/gis/stormwater/sdsi/d7/photos/dp/110_s_22_12966_dis_34_0358_118_2749/.
Then I can add 1.jpg so its reads:  http://www.dot.ca.gov/hq/env/gis/stormwater/sdsi/d7/photos/dp/110_s_22_12966_dis_34_0358_118_2749/1.jpg
I wanted to do this using a script within the configure pop/add photo section of arcgis online if possible. I have seen this done before as I stated earlier in this thread: Show attached images inside popup with ArcGIS Online? - Geographic Information Systems Stack Exchang... (What is the programming language in this thread? Javascript?)
I have several layers like this and this wouldn't be practical to download everyone and make the field changes in arcmap
Brandon
XanderBakker
Can you share the URL to the service you're using to have a look what can be achieved?
BrandonPrice
This is great. This works just. Only for https it seems.
BrandonPrice
works just fine*
BrandonPrice
Sorry. Wrong thread.
BrandonPrice
Can you revise your comments?
