Greetings, I have an app using the Info Summary widget within a dashboard theme that worked fine before the December 2017 update. Ever since, I am unable to select a feature within the widget and display a popup while using the dashboard theme. The widget seems to work properly in all other Web AppBuilder themes. I have duplicated this issue using many other web maps and layers within our organization.
Thank you!
Solved! Go to Solution.
Bug has been logged (BUG-000112092) and can be viewed here
Hi Chris,
Sounds like this may be a bug. I would recommend logging a case with Esri Technical Support so they can log this bug and the Esri's development team is aware.
Hi Chris,
I recently discovered this same issue with my web app. I am using WAB DE v.2.7
The solution that worked for me was grabbing the info summary widget from v.2.6
https://developers.arcgis.com/downloads/apis-and-sdks?product=web-appbuilder
Hope that helps.
Mark
