How to Open *.mxd file with Qt c++ sdk?
1636
12-19-2017 07:23 PM
hoangtruongutm
Hi, everybody.
I have a problem about reading *.mxd file.
And more thing. When I add GraphicLayer into map. Exactly, I add it to layer(0). It was not appeared.
But if I had a map in Layer(0). And I add again, it come to layer(1), it was appeared.
Thank full.
My code:
EsriRuntimeQt::Point point1(1500000, 7500000, spatialReference);
EsriRuntimeQt::Graphic* graphic1 = new EsriRuntimeQt::Graphic(point1,txtsymbol1);
EsriRuntimeQt::GraphicsLayer* grLayer = new EsriRuntimeQt::GraphicsLayer(this);
grLayer->addGraphic(graphic1);
m_map->addLayer(grLayer);
m_map->fullExtent();
LucasDanzinger
Esri Frequent Contributor
Regarding the MXD, ArcGIS Runtime does not open this file format. Rather, you can open the MXD in ArcMap/Pro, and create a web map, map service, mobile map package, etc, and then open that data in ArcGIS Runtime.
Regarding your graphic issue, the layers draw in the order specified, so if you are adding a new graphics layer to your map, addLayer will add your layer to n+1, where n is the length of the layer list. If you want to control z order of the layers, you could instead use insertLayer.
LucasDanzinger
hoangtruongutm
thank you verry much.
      • by hoangtruong utm ***
2018-01-23 14:35 GMT-08:00 Lucas Danzinger <geonet@esri.com>:
GeoNet <https://community.esri.com/?et=watches.email.thread>
Re: How to Open *.mxd file with Qt c++ sdk?
reply from Lucas Danzinger
<https://community.esri.com/people/LDanzinger-esristaff?et=watches.email.thread>
in ArcGIS Runtime SDK for Qt - View the full discussion
<https://community.esri.com/message/744349-re-how-to-open-mxd-file-with-qt-c-sdk?commentID=744349&et=watches.email.thread#comment-744349>
