Integrate workforce with customized survey app
3892
8
12-18-2017 06:15 AM
JamesTedrick
Esri Esteemed Contributor
Hi Italo,
To work out of the box with workforce, you would need to use arcgis-survey as the url scheme of the application; this might cause issues if a device also had regular Survey123 installed.  Alternatively, you can provide a custom url scheme for your application and then customize the link generated in the Workforce project to point to your application instead using ArcGIS Online Assistant or a similar tool; I'd recommend the demo theater presentation "Remotely Invoking Apps" for guidance on this (Slides Video)
CraigGillgrass
Hello Italo,
This topic in our documentation for Workforce will help you get started:
Create your first project—Workforce for ArcGIS | ArcGIS
JamesTedrick
Hi Italo,
ItaloZanotti2
Thanks James very useful your answer.
nelsmickaelson
Is it possible to call a web page with URL parameters from workforce using the same technique? It would be on an IOS device. Is there a URL schema for safari? or does it need to be an IOS app?
"id": "default-safari",
"prompt": "Call Web page",
"urlTemplate": "safari://?webpageurl&center=${assignment.latitude},${assignment.longitude}"
Thanks for any help!!!
Nels
JamesTedrick
Hi nels,
The URL schema for a web browser like Safari is standard https://
Please refer to the web form URL parameter description at Integrate with other apps—Survey123 for ArcGIS | Documentation
nelsmickaelson
Hi James,
Thanks for getting back to me. Bear with me and I appreciate your patience. I have read the documentation and understand how to link to survey123, collector, navigator, etc.... But what do I need to use to open the web page I'm trying to link to from workforce - what would the json look like? Items in red below:
"id": "xxxx-xxx",
"urlTemplate": "xxxxxxxxx"
nelsmickaelson
I figured out how to do this with Google Chrome on the device. Here is the json in case anyone else is trying to do this from Workforce:
"id": "default-googlechromes",
"prompt": "Open GIS Website",
"urlTemplate": "googlechromes://gis.clark.wa.gov/gishome/index.cfm"
Here is how you can link to Google Maps as well
"id": "default-comgooglemaps",
"prompt": "Open location in Google Maps",
"urlTemplate": "comgooglemaps://?center=${assignment.latitude},${assignment.longitude}&zoom=14&views=traffic"
nelsmickaelson
And here is the JSON where you simply specify the URL and it will open with the default browser on the device.
"id": "",
"prompt": "No utilities found",
"urlTemplate": "https://website/somepage?pid=update_status&utilityreviewid=${assignment.workorderid}&locatestatusid=6"
"id": "",
"prompt": "Complete Review",
"urlTemplate": "https://website/somepage?pid=update_status&utilityreviewid=${assignment.workorderid}&locatestatusid=2"
