Error in calculate field using Python
3317
12-14-2017 03:20 PM
DuminduJayasekera
I have the following python script to create a TEXT column called "SEC" and then I need to perform a Field calculator operation for the SEC column. I want to read the corresponding string in the "mtrs" column and and fill in SEC column. I have performed this task manually and it worked. I need to slice the "mtrs" string like this "S{}".format(int( !mtrs! [17:19]))" and fill in SEC column.
My script below give me an error in line 14. SyntaxError. invalid syntax.
Can somebody help me to fix this and make this work?
Thanks in advance,
# Import system modules
import arcpy
from arcpy import env
# Set environment settings
env.workspace = "H:/Test/Points.gdb"
# Set local variables
inFeatures = "plsssection_test_p1"
fieldName1 = "SEC"
length = 20
expression = ""S{}".format(int( !mtrs! [17:19]))"
# Execute AddField twice for two new fields
arcpy.AddField_management(inFeatures, fieldName1, "TEXT", length, "", "")
arcpy.CalculateField_management(inFeatures, "SEC",expression, "PYTHON_9.3")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
a = ""S{}".format(int( !mtrs! [17:19]))"
  File "<ipython-input-1-6325b07dafa7>", line 1
SyntaxError: invalid syntax
watch your quotes... throw a single around the whole expression
a = '"S{}".format(int( !mtrs! [17:19]))'
# --- no error
JoshuaBixby
MVP Esteemed Contributor
What about:
import arcpy
fieldName1 = "SEC"
length = 20
expression = "!mtrs![17:19]"
DuminduJayasekera
Thanks for the reply.
# --- no error
DuminduJayasekera
Thank you. It worked.
