unsure about this error message
2757
12-14-2017 10:24 AM
AldousTsang
I was trying to view my survey via web browser thru (survey123.arcgis.com) and encountered this error message.
Error loading survey. Error message: Error trying to parse XML instance "StreetAddress". Unable to get property 'firstChild' of undefined or null reference, External instance "FacilityName" is empty., External instance "StreetAddress" is empty., External instance "Zip" is empty., External instance "APN" is empty., External instance "WDID" is empty., External instance "addresss" is empty., FormLogicError: Could not evaluate: instance(/model/instance[1]/Industrial_Commercial/agency)/root/item[CI_Key = '']/StreetAddress, message: Function "{}instance" does not exist. Please contact survey author.
using pulldata and select_one_external/external_choices
-Aldous
Tags (3)
JamesTedrick
Esri Esteemed Contributor
Hi Aldous,
Can you share the XLSfile?
AldousTsang
Can I email it to you?
JamesTedrick
Yes, I'm at jtedrick At Esri.com
AldousTsang
Error is caused by web form not recognizing a variable as the .csv name.
