How to find hypotenuse using python code
1094
12-13-2017 07:37 AM
MonicaBeaton
I have a polyline feature class (sewer pipes) with upstream and downstream values but because the z values are not enabled on the dataset, I need a quick way to produce a "true length" or 3D value. How can I plug into the field calculator:
(upstream - downstream) squared + shape.length squared = hypotenuse? using python (or VB?)
Thanks to anyone, I am not a coder just a novice with python still.
I should add that I have created a new field called True_Len to calculate the result on, not trying to change an existing field value.
MonicaBeaton
For anyone with the same question; after a few trials, my colleague and I came up with this:
math.sqrt((!Shape_len! * !Shape_len!) + ((!UpstreamIn! -  !Downstream!) * ( !UpstreamIn! - !Downstream!)))
There's likely an easier way to produce the same results but isn't that the same with most geoprocessing?
