Generate token from portal URL
5793
12-11-2017 01:13 AM
MagalyClément-Zaber
Since I update arcgis 104.1 to 10.5.1, I have an issue when i want to generate token :
parameters = urllib.urlencode({'username' : username,
 'password' : password,
 'client' : 'referer',
 'referer': portalUrl,
 'expiration': 60,
 'f' : 'json'})
 response = urllib.urlopen(portalUrl + '/sharing/rest/generateToken?', parameters).read()
 try:
 jsonResponse = json.loads(response)
 if 'token' in jsonResponse:
 self.token = jsonResponse['token']
 return self.token
 elif 'error' in jsonResponse:
 print(jsonResponse['error']['message'])
 for detail in jsonResponse['error']['details']:
 print(detail)
 sys.exit(2)
 except ValueError, e:
 print('An unspecified error occurred.')
 print(e)
IOError: [Errno socket error] [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)
Do you have any idea to solve this issue ?
Thx.
Tags (3)
JakeSkinner
Esri Esteemed Contributor
Hi Magaly,
Try the following.  The try/except should bypass the SSL Certificate error.
import urllib, urllib2, json, ssl
username = "portal"
password = "agol123"
tokenURL = 'https://portal.esri.com/portal/sharing/rest/generateToken/'
params = {'f': 'pjson', 'username': username, 'password': password, 'referer': 'https://portal.esri.com'}
req = urllib2.Request(tokenURL, urllib.urlencode(params))
try:
    response = urllib2.urlopen(req)
except:
    gcontext = ssl.SSLContext(ssl.PROTOCOL_TLSv1)
    response = urllib2.urlopen(req, context=gcontext)
data = json.load(response)
token = data['token']
print(token)
JakeSkinner
Hi Magaly,
username = "portal"
try:
except:
print(token)
MichaelAugust
I'm trying to run the example python script here:
Example: Prepare Esri basemaps for use in offline workflows—Portal for ArcGIS (10.5.x) | ArcGIS Ente...
and am getting the same error on our 10.5.1 Portal - could you show me how to bypass the SSL error using this script as an example? Thanks!
fabianheredia2
this dont work beacuse the urllib2 inst use in the arcgis pro python configuration and when I try with urllib3 generate others errors
MagalyClément-Zaber
Thank you very much, it works !!
