ArcMap crashing on simple raster calculation in Python window
2724
12-08-2017 08:56 AM
AlexTurner4
I have a Python script that has been crashing ever since I had to update to Windows 10 but always worked prior. Not sure if that is the reason or just a coincidence. I have isolated the problem to the part where I try some basic map algebra on rasters. The code below is what I have been trying in the Python window and ArcMap crashes every time with no error. It seems to be related to accessing the individual band because the code works on the main raster. Also, if I add the Band into ArcMap manually and run the code using the layer it also works. I have tried various ways of representing the path to Band 4 but no luck.
from arcpy.sa import *
Rast = r'C:\Projects\m_3409443_ne_15_1_20150808.tif'
Band4 = Rast + r'\Band_4'
calc = Raster(Band4) < 60
DanPatterson_Retired
I usually convert to numpy.. but give this a go
import arcpy
# ---- band 1
r = arcpy.MakeRasterLayer_management("c:/temp/untitled.png", "test", "#", "#", "1")
# ---- now see what you have
r
<Result 'test'>
r[0]
<arcpy._mp.Layer at 0x1c1af537588>
ras = arcpy.sa.Raster('test')
# ---- then knock yourself out
dir(ras)
   ['__abs__', '__add__', '__and__', '__bool__', '__class__', '__delattr__', '__dir__',
    '__divmod__', '__doc__', '__eq__', '__floordiv__', '__format__', '__ge__',
    '__getattribute__', '__gt__', '__hash__', '__iadd__', '__iand__', '__ifloordiv__',
    '__ilshift__', '__imod__', '__imul__', '__init__', '__invert__', '__ior__',
    '__ipow__', '__irshift__', '__isub__', '__itruediv__', '__ixor__', '__le__',
    '__lshift__', '__lt__', '__mod__', '__mul__', '__ne__', '__neg__', '__new__',
    '__or__', '__pos__', '__pow__', '__radd__', '__rand__', '__rdivmod__',
    '__reduce__', '__reduce_ex__', '__repr__', '__rfloordiv__', '__rlshift__',
    '__rmod__', '__rmul__', '__ror__', '__rpow__', '__rrshift__', '__rshift__',
    '__rsub__', '__rtruediv__', '__rxor__', '__setattr__', '__sizeof__', '__str__',
    '__sub__', '__subclasshook__', '__truediv__', '__xor__',
    'bandCount',
    'catalogPath',
    'compressionType',
    'extent', 'format',    # ----- formatting liberties taken
    'hasRAT',
    'height',
    'isInteger',
    'isTemporary',         # you get the idea
    'maximum',
    'mean',
    'meanCellHeight',
    'meanCellWidth',
    'minimum',
    'name', 'noDataValue', 'path', 'pixelType', 'save', 'spatialReference', 'standardDeviation', 'uncompressedSize', 'width']
ras.pixelType
'U8'
ras.height, ras.width
(190, 250)
ras.bandCount, ras.format
(1, None)
# ---- etcetera
what you are trying does not form a correct way to get to a band in a raster.  You are right in that you can access the whole raster (ie the *.tif) and if you add the individual band to arcmap it works.  That is because it is a raster layer and not a raster.
AlexTurner4
The weird thing is that this exact code worked for me prior to updating to Windows 10. I never had problems accessing the bands this way. What would the correct way to access the band be?
import arcpy
# ---- band 1
r
<Result 'test'>
r[0]
dir(ras)
    'bandCount',
    'catalogPath',
    'compressionType',
    'hasRAT',
    'height',
    'isInteger',
    'maximum',
    'mean',
    'meanCellHeight',
    'meanCellWidth',
    'minimum',
ras.pixelType
'U8'
(190, 250)
(1, None)
# ---- etcetera
AlexTurner4
That worked. Thanks! Should have been using this from the start.
