Error: 499 Error transferring - server replied: Proxy Error
2897
5
12-07-2017 08:45 AM
SebastiánArdila
Hi everyone, I am having an issue with Survey123 Connect. It works properly on the Connect when I run it, but by the time I want to publish it through Connect, an 499 code error shows up: " Error transferring https://survey123.arcgis.com/api/beta/xform2webform - server replied: Proxy Error.
I already saw a similar case and the response was an instability on the server, but I have waited couple of weeks and still does not work by publishing it daily. Same error pops up.
Any recomedation?
I would appreciate any assistance. Need to send a project and haven't added this yet. Have a nice day,
ichivite-esristaff
JTedrick-esristaff
JamesTedrick
Esri Esteemed Contributor
Hi Sebastián,
Could you please retry? We saw some minor issues with the Survey123 API this morning that have been addressed.
SebastiánArdila
Nothing! Still same error, same code. I have been trying for 2 weeks and same issue.
JamesTedrick
Hi Sebastián,
Does your survey have a long set of choices?  This is the most common issue when specifically at the webform processing.  If so, make them an external select, if possible - Cascading and external selects—Survey123 for ArcGIS | ArcGIS
SebastiánArdila
Hi James,
Yes, I have a long set of choices (almost 10.000). I was just thinking about creating an external sheet, but did not see it necesary because it works on Connect. I will try and reply later. Thank you so much.
SebastiánArdila
Hi, James,
It did work!! Thank you so much, I really appreciate your recomendation. Now it published so fast.
