Reclass null values in text field using Calculate Field
5486
5
12-05-2017 04:26 AM
DataOfficer
I have a text field called 'Description' that contains some <Null> values that I wish to update to 'Hedgerows' while keeping all other values the same.
Using Calculate Field in Pro, I tried the following:
Expression:
Reclass (!Description!)
Code block
def Reclass(Description):
if (IsNull)
return Hedgerows
The expression was successfully verified but I then got the following error message when running the tool:
Error 00539: Error running expression: Reclass (u"Buildings")
File "<expression>", line 1, in <module>
File "<string>, line 2, in Reclass
Name Error: name 'IsNull' is not defined
Failed to execute (CalculateField).
Any suggestions? I'm a complete novice when it comes to Python.
TedKowal
Honored Contributor
Much Ado About Nothing   is a excellent document written by curtvprice  Dan Patterson‌  describing techniques in dealing with Null values.
def reclass (myString):
    if myString is None:
         return 'Hedgerow'
    return myString
reclass(!Description!)‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DataOfficer
Thank you, I will try this now! Just out of interest, how would this code change if dealing with numerical values rather than string?
TedKowal
Honored Contributor
Lot of ways to appoach it ... one way is to make the number a string... but the test doesnt care whether or not the variable is a number or string  so testing myNumber is None would be valid as well -- It is what you return to the field that is important.
def reclass (myNumber):
    if str(myNumber) is None:
         return 911
    return myNumber
reclass(!NumberField!)
KoryKramer
Esri Community Moderator
Since you're a novice to python, I just wanted to make sure you were aware of the Helpers in Pro:
Adding your story about Reclass on this idea ArcGIS Pro Field Calculate Helpers‌ would be worthwhile.
The reclass example is in the doc: Calculate Field examples—Data Management toolbox | ArcGIS Desktop  (Ctrl+F 'reclass')
That doc on examples might be helpful to you in the future as well.
Cheers
DataOfficer
Thanks - this is the example I tried to follow but wasn't sure how to handle 'Null' values (in a string or numeric field). I think I'm beginning to get a better sense of it. What I would really like to see is a feature class version of the 'Reclassify' tool so users that aren't familiar with Python can easily define 'Start' and 'End' values without using code.
Anyway, thanks for the help!
