Travel Mode Error in Direction Widget WAB
589
12-05-2017 02:48 AM
AlbertoLópez
New Contributor III
Hello;
I have developed a WAB application with the Direction widget. The route web service has 2 travel modes.
In the startupt function of the widget I set  the travel mode to one of them (not the default ) and initialize the Direction dijit:
var routeTask = new RouteTask(this.config.routeTaskUrl1);
routeTask.getServiceDescription().then(lang.hitch(this, function (serviceInfo) {
        travelModes=serviceInfo.supportedTravelModes;
        this._dijitDirections.routeParams.travelMode= travelModes[1];
 this._dijitDirections = new Directions(options, directionContainer);
 this._dijitDirections.startup();
After the line:  this._dijitDirections.startup (); the property travelMode is correct because it has the value that I have previously assigned:  travelModes [1].
But when the calculation of the route starts, the travelMode property changes to the other travel mode (travelModes [0]) and the calculation is made with this other travel mode.
I can see it in the directionStart event with the debugging tools.
Any suggestions about  how to make the calculation  with the travel mode that I configured at the start (this._dijitDirections.routeParams.travelMode = travelModes [1];).?
the combo always shows the travel mode that I do not want.
Js api version 3.22
Thank you very much.
RobertScheitlin__GISP
Alberto,
   You need to use this._dijitDirections.setTravelMode(travelModes [1]);
https://developers.arcgis.com/javascript/3/jsapi/directions-amd.html#settravelmode
Alberto,
