ArcGIS pro freezes every time I add a legend from imported MXD map
1251
12-05-2017 04:44 AM
JoeNunn
Hi - i have imported an MXD into arcmap.  It works fine and appears in a layout.
When i try to add a legend the item appears on the map (but with no layers in it). I can pan round the map but the drawing icon appears and everything else is frozen.   I can close the layout but everything is grayed out.
Any ideas?  IS it due to the content of the map?
thanks
joe
Tags (3)
DanPatterson_Retired
try to rebuild from the original data and see if that works first
JoeNunn
Hi Dan - just copied all the layers onto another map and it worked ok.  Must have had an issue with the imported map.
thanks
joe
