Definition Query not working after join?
898
12-01-2017 05:34 PM
forestknutsen1
I have a query that is failing after a join. I have greatly simplified the query to try and pin down the problem. We are using a SDE source with in Oracle 12c.
The cut down query...
exists (select * from ARCFM8.Transformer)
Working fine before the join....
Not working after the join....
Suggestions?
AbdullahAnter
Honored Contributor
Check your Query After *FROM statement , because it changed.
forestknutsen1
Thanks for taking the time to reply Abdullah.
I too noticed the table name change in the dialog. Unfortunately changing it does not affect the query error behavior.
It is also weird because the fully qualified name for the transformer fields should be ARCFM8.Transformer.{field name}. And not ARCFM8.Transformer_Transformer_FM.{field name}.
Even very simple queries fail...
