Error message: Managed Debugging Assistant 'PInvokeStackImbalance' has detected a problem in 'C:\Program Files (x86)\ArcGIS\Desktop10.4\bin\ArcMap.exe'.
1919
12-01-2017 12:57 PM
JoseSanchez
Hello everyone,
I am getting this error message after importing an AddIn to  and started comiling the code with VS 2015:
Framework:  VS 2015 and ArcGIS 10.4.1
PInvokeStackImbalance occurred.
Message: Managed Debugging Assistant 'PInvokeStackImbalance' has detected a problem in 'C:\Program Files (x86)\ArcGIS\Desktop10.4\bin\ArcMap.exe'.
Additional information: A call to PInvoke function 'ESRI.ArcGIS.ADF.Local!ESRI.ArcGIS.ADF.Native::memcpy' has unbalanced the stack. This is likely because the managed PInvoke signature does not match the unmanaged target signature. Check that the calling convention and parameters of the PInvoke signature match the target unmanaged signature.
JoseSanchez
