Unable to update ArcGIS Runtime SDK for iOS from 10.2.5 to 100.1.1
2286
11-30-2017 02:57 AM
MadhuA
I'm using ESRI maps in my application, currently due to some features we are sticking the cocoa pods version to 0.39.0. Now i'm trying to update ArcGIS runtime sdk version to 100.1.1 from my earlier version which is 10.2.5. So i have made the modifications in my pod file which pointing to v 100.1.1 and when i run pod install, i'm getting the below error.
Analyzing dependencies
[!] Unable to satisfy the following requirements:
- `ArcGIS-Runtime-SDK-iOS (~> 100.1.1)` required by `Podfile`
[!] CocoaPods was not able to update the `master` repo. If this is an unexpected issue and persists you can inspect it running `pod repo update --verbose`
My question is the latest v 100.1.1 compatible with cocoa pods v 0.39.0?
Any help is much appreciated.
Thank you.
Nicholas-Furness
Have you tried "pod repo update --verbose" to update your local cocoapods repo cache?
Failing that, you could try to manually delete the cache folder in ~/Library/Caches/CocoaPods
MadhuA
Hi Nicholas,
I have tried the same. I didn't work out. Is the ArcGIS Run time iOS SDk Version 100.1.1 compatible with cocoapods v0.39.0. I even tried changing the Deployment target to iOS 8 and iOS 9 in the pod file, but no luck. Please help me.
MadhuA
I have updated my latest pod version from 0.39.0 to v1.3.1 and even now when i try to update the or install the pod with  ArcGIS-Runtime-SDK-iOS (~> 100.1.1). This is what i'm facing.
$pod install
Re-creating CocoaPods due to major version update.
[!] Unable to find a specification for `ArcGIS-Runtime-SDK-iOS (~> 100.1.1)`
$ pod outdated
Updating spec repo `master`
  $ /usr/bin/git -C /Users/PW/.cocoapods/repos/master fetch origin --progress
  remote: Counting objects: 9, done.
  remote: Compressing objects: 100% (8/8), done.
  remote: Total 9 (delta 5), reused 0 (delta 0), pack-reused 0
  From https://github.com/CocoaPods/Specs
     35d104c5b58..075f335e119  master     -> origin/master
  $ /usr/bin/git -C /Users/PW/.cocoapods/repos/master rev-parse --abbrev-ref HEAD
  master
  $ /usr/bin/git -C /Users/PW/.cocoapods/repos/master reset --hard origin/master
  HEAD is now at 075f335e119 [Add] ZPageControl 0.0.1
No pod updates are available.
$ pod update ArcGIS-Runtime-SDK-iOS
Updating local specs repositories
  master
Nicholas-Furness
You might try moving your ~/.cocoapods folder out of the way in case it's confused/corrupted by the Cocoapods version update, and doing a fresh "pod install".
