Change output filename by adding a text in Python
7189
5
11-27-2017 08:09 AM
DuminduJayasekera
HI,
I need to add "_var86" to the output file in the code below. How can I achieve it in the code below.
Thanks in advance.
import arcpy, sys
from arcpy import env
from arcpy.sa import *
# Input data source
arcpy.env.workspace = r"C:/Users/Desktop/weekly_avg_project"
# Set output folder
OutputFolder = r"C:/Users/Desktop/weekly_avg_project/output"
# Loop through a list of files in the workspace
NCfiles = arcpy.ListFiles("*.nc")
for filename in NCfiles:
 print("Processing: " + filename)
 inNCfiles = arcpy.env.workspace + "//" + filename
 fileroot = filename[0:(len(filename)-3)]
 TempLayerFile = "SM_amount"
 outRaster = OutputFolder + "//" + fileroot
 # Process: Make NetCDF Raster Layer
 outfile = arcpy.MakeNetCDFRasterLayer_md(filename, "var86", "lon", "lat", TempLayerFile, "", "", "BY_VALUE")
 proj_ras = arcpy.ProjectRaster_management(outfile, "C:/Users/Desktop/weekly_avg_project/project_ras","GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]", "NEAREST", "0.125 0.125", "NAD_1983_To_WGS_1984_1", "", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]")
 # Process: Copy Raster
 arcpy.CopyRaster_management(proj_ras, outRaster + ".tif", "", "", "", "NONE", "NONE", "")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Tags (3)
MitchHolley1
I see... the below code may work.
import arcpy, sys
# Input data source
# Set output folder
 fileroot = filename[:(len(filename)-3)] + '_var86'
#fileroot = filename[:-3] + '_var86' #I think this will work too- and is easier to read
MitchHolley1
Do you need to just rename the output filename?  If so, it seems like the output layer is currently the 'TempLayerFile' variable.  You can rename that like the code below.
import arcpy, sys
# Input data source
# Set output folder
 TempLayerFile = "SM_amount_var86"
DuminduJayasekera
No. I need to change the file name for the "outRaster" not the "TempLayerFile"
DuminduJayasekera
I need to add "_var86" to the filename which will be the output name for the raster.
MitchHolley1
import arcpy, sys
# Input data source
# Set output folder
DuminduJayasekera
Thanks. it worked.
