Map extent changed event
1428
11-23-2017 04:03 AM
MaxMax2
Is there an event when visible extent of the current map changed? I want to track such changes to update some values in my add-in. Or maybe there is a workaround for this task?
UmaHarano
You can use the MapViewCameraChangedEvent for this.  http://pro.arcgis.com/en/pro-app/sdk/api-reference/index.html#topic12830.html
The ViewExtentChanged event is in an internal namespace - they could change anytime. So not recommended to use anything from a Pro API Internal namespace.
Also, there are a couple of samples in the arcgis-pro-sdk-community-samples that uses the MapViewCameraChangedEvent.
Uma
MaxMax2
I've found that event. It is ViewerExtentChanged from the ArcGIS.Desktop.Internal.Mapping. It is possible to attach handler to this event with the Subscribe method.
UmaHarano
Uma
