No features shown in attribute table
1795
6
11-13-2017 02:00 PM
RalphBradt1
I have published a survey which shows up in AGOL as a hosted Feature Layer. I entered a test survey but, although it says there is 1 feature, it will not show up in the table. When I open the feature laver in map viewer i get the message, "The layer, FOMELC Wilderness Data collector v2, was not drawn completely because it has too many features to draw. Try zooming in to a smaller area." There is only one feature to draw and it will not show. Any ideas? I deleted the survey and republished it with the same result.
JohnathanHasthorpe
Hi Ralph - can you confirm where the survey was published - Web or Connect, and if the latter, please share you survey XLS with me and I will take a look.
[email protected]
John
RalphBradt1
I published it in Connect and am emailing you the XLS. Now when I try to look at the table, it says there are 2000 features, but none are shown.
RalphBradt1
I reopened it in the map viewer after republishing the survey, and it says there are 3 features (which should be correct), but I still can't see any in the table and still get the same message.
RalphBradt1
I have created a new survey from the XLS, named something different, published it, added a survey, and it has the same problem.
JohnathanHasthorpe
Hi - you put a . in the DFno. question name and this broke the feature service.
If you remove this and republish - all will be working.
John
RalphBradt1
Yes! Thanks so much, John! That did the trick.
