Custom icon switch to default after select and unselect feature in feature class
4547
10
11-06-2017 11:48 PM
ZdeněkSoldán
I have some feature layers created in my code from feature collection. In the feature collection I have defined a default icon for this layer. Further in the code I change the icon for some features according some parameters.
When I open Attribute Table widget with this layer and select the feature with different icon than default and after that unselect this feature it have default icon not the icon I defined for this feature.
How can I preserve the defined icon in such cases?
Thanks a lot!
RobertScheitlin__GISP
Zdeněk,
   It sounds like you are setting the graphics symbol individually. If you use a unique value renderer instead you should not have this issue.
Zdeněk,
ZdeněkSoldán
Hello Robert,
yes I'm. Can you explain me what do you mean with unique value renderer and how to use it?
Thanks a lot
ZdeněkSoldán
Ok, I looked what is unique value renderer and it is not usable for me. I have png icons as a symbols and I need to use them.
Zdeněk,
   There is NO reason why you can not use png files in your implementation of a Unique value renderer.
ZdeněkSoldán
Robert,
I tried to implement Unique value renderer and I made some progress but still have some issue. In my Layer List widget it looks good. I have there all needed icons but in map there is nothing. No icons for my features.
Zdeněk,
   I would have to see your implementation of the UV renderer.
ZdeněkSoldán
Here it is.
startup: function () {
        this.inherited(arguments);
        var map = this.map;
        var SSZFeatureLayer;
var SSZFeatureCollection = {
          "layerDefinition": null,
          "featureSet": {
            "features": [],
            "geometryType": "esriGeometryPoint"
SSZFeatureCollection.layerDefinition = {
          "geometryType": "esriGeometryPoint",
          "objectIdField": "ObjectID",
          "spatialReference": {
            "wkid": 4326,
            "latestWkid": 4326
          "drawingInfo": {
            "renderer": {
              "type": "simple",
              // "symbol": {
              //   "type": "esriPMS",
              //   "url": "images/traffic_lights_005826.svg",
              //   "contentType": "image/svg",
              //   "width": 17,
              //   "height": 17
          //"minScale":50000,
          "fields": [{
            "name": "ObjectID",
            "alias": "ObjectID",
            "type": "esriFieldTypeOID"
            "name": "serialno",
            "alias": "ID zařízení",
            "type": "esriFieldTypeString"
            "name": "desc",
            "alias": "Popis",
            "name": "devtype",
            "alias": "Typ zařízení",
            "name": "locality",
            "alias": "Lokalita",
            "name": "street1",
            "alias": "Ulice 1",
            "name": "street2",
            "alias": "Ulice 2",
            "name": "timeStamp",
            "alias": "Zmena stavu",
            "name": "color",
            "alias": "Barva",
var devPopupTemplate = new PopupTemplate({
          title: "<b>Sériové číslo</b>: {serialno}",
          //descritpion: "<table><tr><th><b>Popis</b>:</th><th>{desc}</th></tr><tr><th><b>Typ zařízení</b>:</th><th>{devtype}</th></tr><tr><th><b>Lokalita</b>:</th><th>{locality}</th></tr><tr><th><b>Ulice 1</b>:</th><th>{street1}</th></tr><tr><th><b>Ulice 2</b>:</th><th>{street2}</th></tr></table>"
          description: "<b>Popis</b>: {desc} </br><b>Typ zařízení</b>: {devtype} </br><b>Lokalita</b>: {locality} </br><b>Ulice 1</b>: {street1} </br><b>Ulice 2</b>: {street2}</br><b>Zmena stavu</b>: {timeStamp} "
SSZFeatureLayer = new FeatureLayer(SSZFeatureCollection, {
          infoTemplate: devPopupTemplate,
          visible: false,
          showLabels: true,
          outFields: ["*"]
var defaultSymbol = "images/traffic_lights_005826.svg"
        var renderer = new UniqueValueRenderer(defaultSymbol, "color");
        renderer.addValue("000000",new PictureMarkerSymbol("images/traffic_lights_000000.svg",17,17));
        renderer.addValue("0000A0",new PictureMarkerSymbol("images/traffic_lights_0000A0.svg",17,17));
        renderer.addValue("0000FF",new PictureMarkerSymbol("images/traffic_lights_0000FF.svg",17,17));
        renderer.addValue("7F7F7F",new PictureMarkerSymbol("images/traffic_lights_7F7F7F.svg",17,17));
        renderer.addValue("9E0B0E",new PictureMarkerSymbol("images/traffic_lights_9E0B0E.svg",17,17));
        renderer.addValue("005826",new PictureMarkerSymbol("images/traffic_lights_005826.svg",17,17));
        renderer.addValue("8000FF",new PictureMarkerSymbol("images/traffic_lights_8000FF.svg",17,17));
        renderer.addValue("F7901E",new PictureMarkerSymbol("images/traffic_lights_F7901E.svg",17,17));
        renderer.addValue("FF0000",new PictureMarkerSymbol("images/traffic_lights_FF0000.svg",17,17));
        renderer.addValue("FFF200",new PictureMarkerSymbol("images/traffic_lights_FFF200.svg",17,17));
        SSZFeatureLayer.setRenderer(renderer)
SSZFeatureLayer.on("click", function (evt) {
          map.infoWindow.setFeatures([evt.graphic]);
map.on("layers-add-result", function (results) {
          requestDevices();
map.addLayers([SSZFeatureLayer])
function requestDevices() { Function to request the data}
Do not include:
          "drawingInfo": {
            "renderer": {
              "type": "simple",
              // "symbol": {
              //   "width": 17,
              //   "height": 17
          //"minScale":50000,
in your layerDefinition.
Is the values in your data's color field upper case like?
"7F7F7F"
ZdeněkSoldán
Yes, data's color field is upper case. And I commented the whole part drawingInfo and still nothing in my map.
