Buffer tool for Survey123 Map
5060
13
11-03-2017 03:46 AM
MicheleDe_Santis
Hi to all,
is it possible to add a buffer tool on a Suvey123 Map? I would like to draw a buffer (radius 100m) on my position when the user click on a button. The buffer should be stay fixed on map and erased when the user click on another button. How Can I implement this function?
Thanks to all
JohnathanHasthorpe
Hi Michelle
Currently we don't support this functionality. I could get this added as an enhancement request - but in order to do so, could you provide more details of your workflow and what you are trying to acheive.
John
MicheleDe_Santis
Hi John,
in our application surveyors go into field to sample trees and plants. They wants create a buffer on the map because they wants move inside it. The law imposes samples along 100m from sick plant. Inside our organization does we can modify the source code for this need?
Michele
DanielDery
I developed some Javascript functions to create a buffer around a point/current position. This script uses the UTM coordinates from the point, calculates the UTM coordinates of 360 points around it, converts them all to Lat/Lon and creates a text string to be used in the geoshape Calculate column. You will need to save the .txt file as .js because javascript attachments are surprisingly not supported here.
Please note that this script is not perfect and can be improved. It can also be used in a Repeat to create multiple buffers around the center point.
Daniel Dery
Tags (3)
MonmouthNJGIS
Good Morning Daniel! We love this approach and gave it a try in one of our org's surveys, but we can't get the desired results. We tried on a blank survey as well using the files provided and could not replicate that either. If you're able to take a look at our survey file, do you see any glaring issues?
Thanks in advance for any advice!
rrhee_bcfpd
Not sure if you're still looking for a solution, but I got it working on Survey123Connect 3.18 with a few tweaks.
  1. Change "round((...), 7)" to (...).toFixed(7) in lines 114 and 115
  2. If you want to run it on a web-based form, replace "center_X" with "parseFloat(center_X)" in line 112 and 113
  3. * I currently have the question that runs the javascript script to have a field length of 10000 on a null field, but it doesn't look like Daniel did the same. Not 100% sure if it's required, but might be worth a try
  4. * I also added a second question that takes the text from the question running the javascript and uses substr(${...}, 0, string-length(${...} - 2)) to trim off the trailing "; " that gets appended to the last coordinate pair, but again, it doesn't look like Daniel did the same.
I attached my modification of the script below, but I did shrink the script down to a single function so it will look different, but it's doing the same thing. No guarantee it will work, but I also ran into a few issues, but this solution is possible with a little tweaking and experimentation with the script.
MichelleWilliamsERM
WOW, and thank you @DanielDery that looks sexy.
GrishaPost
Thank you, @DanielDery and @rrhee_bcfpd!
MichelleWilliamsERM
I'm having a weird issue. OB1, you're my only hope.
I'm using the form and the updated code from above, but my buffer isn't around my point in Beaumont, CA; it's in Arkansas. Have you encountered this issue before, and if so, how did you resolve it?
rrhee_bcfpd
Oops, looks like I was a bit short-sighted on my last post, and I hard-coded my UTM zone instead of leaving that as a function parameter. Likewise, I also scratched the part of the script that accounts for northern/southern hemispheres for simplicity, so that would require some modification for use in the southern hemisphere.
For the UTM zone, just replace:
  1. The function definition line "function generateBuffer..." with "function generateBufferCoordinates(zone, center_Y, center_X, buffer_dist) {"
  2. Line 49 starting with "var buff_lon = (((15 > 0...", replace the line with "var buff_lon = (((zone > 0) && (6 * zone - 183.0) || 3.0) - _a3).toFixed(7);"
  3. Then just make sure you're passing the UTM Zone parameter as the first parameter on the pulldata calc where the js call is being made
Alternatively, if you know that all of your operations are occurring in the same UTM Zone (like I did), you can simplify the script and ignore step 1 and 3 and just swap out the two "15" values in step 2 with "11" for California.
