Read only fields not displaying in Survey when editing from Inbox
2525
7
11-01-2017 12:05 PM
TonyGroeneveld2
I have created a survey that is preloaded with data from our enterprising data base. The survey is setup to use the inbox. The user can pick an existing survey from the inbox and edit a subset of the fields in the data. There are some fields that I want to display for contextual information but do not want the user to have the ability to change. If I set the readonly property to 'yes'; the data is not displayed.
How do I get read only data to display on the form when editing an existing survey?
MichaelKelly
Hi Tony. This is currently an open issue, but I believe it is being addressed in the next release (2.5). You can participate in the Early Adopter Program if you want to test it out.
The only workaround that I am aware of is to make the field you want to make read-only a hidden field, and then calculate it into a note field.
MichaelKelly
TonyGroeneveld2
Thanks. I was able to get that to work. Here is the relevant columns that you need to populate in the survey123 spreadsheet.
type
name
label
readonly
calculation
bind::esri:fieldType
bind::esri:fieldLength
hidden
Unitid
UnitId
esriFieldTypeString
35
text
Unitid_display
Unit Id:
yes
${UnitId}
null
JamesTedrick
Esri Esteemed Contributor
Hi Tony,
Michael is correct- this will be addressed with the 2.5 release a bit later this month.
TonyGroeneveld2
Great looking forward to the new release
AllisonMuise1
James Tedrick‌ Has this been addressed? I just downloaded v 3.0.132 and I'm still not seeing pre-populated data in my read-only text fields. Interestingly, the read-only data in my decimal fields IS displaying (and read-only).
JamesTedrick
Hi Allison,
Yes, this should be addressed.  Can you share the XLS file?
AllisonMuise1
sent via email
