Doubt on "Select By Attributes" In ArcMap
2515
8
10-30-2017 06:34 AM
PanGIS
Hi guys,
What is sounds very strange to me has probably a meaning for an expert in SQL or in the attribute selection in ArcGIS.
Why, if I search for all the records "greater or equal than" a letter, the letter is included in the search but if I search for "smaller or equal than" a letter, this is excluded?
It works the same either with or without %.
Thanks.
JoeBorgione
Drop the % sign in both of your queries.  Instead  of value >= 'P%' just use >= 'P'  That will get you everything that starts with 'P' through Z.
If you use <= 'P', you'll get everything from A-P as well as those values that start with 0-9.
I use < 'A' all the time to find numerically 'named' streets...
TedKowal
Honored Contributor
It is because SQL compares strings by Ascii Values when using comparison operators.  If you insert a wildcard -- the representative strings returned are included.
for example
"p" > "P"   would return true  -- the decimal value for "p" is 112 and the decimal value for "P" is 80
name >= "P%" would compare name with the returned values of "Pxxxxxx"  So "P" by itself will be excluded, "Paulding" would be included as well as "p" (lower case has a higher ascii value than uppercase).
PanGIS
Thanks for your replies
Joe
even if I drop the % the result I get is exactly the same >= will include P and <= will exclude it.
A bit naive as question maybe, but if I type = my brain expects to get the "P" anyway, but my brain doesn't work in SQL.
Ted ,
you opened the door of a new world
Would you answer apply without considering the wildcard but the simple P?
(Maybe you already answer here above but I need you to confirm )
I checked the lowercase and it is here!! :
JoeBorgione
I just tried it with <= 'P%' on some street names; I got two streets named 'P' and no other streets that start with 'P'.
I can get ALL the streets that start with 'P' using StreetName < 'Q' and of course all the others that go along with that.
To get all the streets that start with 'P' long with all streets less than 'P' I would use:
StreetName <= 'P%' or StreetName like 'P%'
What is your objective with these queries?
Pan gis
TedKowal
Honored Contributor
Without the wildcard you would be comparing ascii value of P to ascii value of P so "in a sense" you are filtering name >= 80 or name <= 80.
Please bear in mind a space also has a value....and in some database would influence the results:    P[space] <> P    "P " <> "P>.
So technically my answer to you is yes....
However it can get complicated real quickly with other bumps in the road that I did not mention --- character sets that you are using will have some influence ... My assumption you are using the standard Latin-1 set.  Another bump in road is the database you are using.... some database use a dictionary for string comparison and others use a binary operation.  So in dictionary sense my example with space would not be correct  "P " = "P" whereas in a database using binary operations my answer would be correct  "P " <> "P".  I was trying real hard in keeping the answer simple.....  When you introduce "NULL" values there are even more issues!
TedKowal
Honored Contributor
Personally I use coding when I am string comparing stuff using < > operators on letters..... then I can compare numbers!
Convert string to ASCII value python - Stack Overflow
JoshuaBixby
MVP Esteemed Contributor
I encourage you to read sql - Equals(=) vs. LIKE - Stack Overflow, I think it will help you understand your results.
ModyBuchbinder
Try name <= 'Pz"
This will find everything that start with a P (accept when it start with Pz) . I do not remember what is the next ascii after z
Have fun
Mody
