Proxy Settings
2477
10-24-2017 05:38 AM
JamesFitzgerald3
Hello All,
Problem:
 I want to share my story map to our intranet users not internet users. Our network is secure so publishing a story map publicly is out of the question. I want to customize the story map journal so users do not have to have a login to AGOL or sign up to my organization AGOL. The user just simply clicks the link and poof...story map opens.
Steps I have completed.
1.) Downloaded Story Map Journal
2.) Downloaded Resource Proxy Code
3.) Hosted Resource code as DotNet
4.) Modified the config.js and proxy.config files
Question:
1. In the Config.js file, Does to urlPrefix need to point to arcGIS Online?
For example, https://AGOL_Organization.maps.arcgis.com/home/index.html or https://AGOL_Organization.maps.arcgis.com
2. In the proxy.config file, Does the serverUrl need to point https://AGOL_Organization.maps.arcgis.com/home/index.html or https://AGOL_Organization.maps.arcgis.com ?
3. Also in the proxy.config file, Do I need additional code and Is this the correct code for oauth2Endpoint?
THANKS!!!!!!!!!!!!!! PLEASE HELP!!!!!!!!!!!!!
JamesFitzgerald3
   A.) Read the Readme file. I resolved my problem through hosting the DotNet within the wwwroot folder and converted into an application.
   A.) I modified the config.js and proxy.config filesConfiguration of Config and Proxy
Question:
It would need to point to https://www.arcgis.com/ or https://AGOL_Organization.maps.arcgis.com if you have an organizational account.
In the proxy.config file, Does the serverUrl need to point to https://AGOL_Organization.maps.arcgis.com?
It would need to point to https://AGOL_Organization.maps.arcgis.com Or to https://www.arcgis.com/
You do not need to use the oauth2Endpoint since it is token based.
Do I need to customize other code?
You do not need to customize any other code.
JamesFitzgerald3
Question:
