Python: If Then with Left Equivalent
1481
6
10-24-2017 07:35 AM
MichaelWalden
Codeblock
Trying to calculate using Python in 10.3 the "Region" field with text based on the first two characters in a string field called "API_10".  Basically, if the left two characters in "API_10" equal "33", then populate "Region" with "North".
JoshuaBixby
MVP Esteemed Contributor
API_10[0:2] or API_10[:2]
JoshuaBixby
JoshuaBixby
Also, just pass the whole column to your function since the function does slicing and checking:  Region = TextValue(!API_10!)
MichaelWalden
Thanks Joshua!
DanPatterson_Retired
Joshua is correct... python slicing is 0 based and exclusive of the slice number, hence
whatever[:2] or whatever[0:2] will return 0 and 1.  The slice is [start:stop:step]
whatever = 'abcdefg'
whatever[0:6:2]
'ace'
whatever[:6:2]
'ace'
or skipping the start and stop
whatever[:6]
'abcdef'
TedKowal
Honored Contributor
When you do a slice or substring in Python and  it starts with "0" then the second number is always the length.  This confused me for a while ..... https://www.dotnetperls.com/substring-python
Or the most succinct descriptor... the python docs
