Running geoprocessing script from custom widget
1355
10-22-2017 10:09 PM
MarkEastwood
Hi all,
I'm taking my first foray into creating a custom widget and am running into some difficulty. The geoprocessing script I am trying to run takes a user entry, and uses that value to create a report. I am having troubles getting the geoprocessing service to run. My script is below:
  define([
"dojo/_base/declare",
"jimu/BaseWidget",
"dijit/_WidgetsInTemplateMixin",
"dojo/aspect",
"jimu/ConfigManager",
'dojo/_base/html',
"jimu/WidgetManager",
"esri/layers/FeatureLayer",
"dojo/query",
"esri/tasks/query",
"esri/tasks/QueryTask",
"dojo/store/Memory",
"dojo/_base/array",
"dojo/on",
"dojo/_base/lang",
"dijit/form/ComboBox",
"dojo/dom",
'jimu/dijit/Message',
'esri/tasks/GPMessage',
'esri/tasks/JobInfo',
'esri/request',
"esri/tasks/Geoprocessor"
function (
declare,
BaseWidget,
_WidgetsInTemplateMixin,
aspect,
html,
ConfigManager,
WidgetManager,
FeatureLayer,
dojoQuery,
Query,
QueryTask,
Memory,
array,
on,
lang,
dom,
JobInfo,
esriRequest,
Geoprocessor,
GPMessage,
Message
return declare([BaseWidget, _WidgetsInTemplateMixin], {
baseClass: "jimu-widget-reportingtool",
queryTask: null,
query: null,
userEntry: null,
gp: null,
postCreate: function () {
this.queryTask = new QueryTask("myservice");
this.query = new Query();
this.query.returnGeometry = false;
this.query.outFields = ["bridge_name_num"];
this.query.where = "bridge_name_num <> '' AND status <> 'Undefined'";
onOpen: function () {
this.queryTask.execute(this.query, lang.hitch(this, this.populateList));
populateList: function (results) {
//Populate the ComboBox with unique values
var zone;
var values = [];
var testVals = {};
//Add option to display all zoning types to the ComboBox
values.push({
//Loop through the QueryTask results and populate an array
//with the unique values
var features = results.features;
array.forEach(features, function (feature) {
zone = feature.attributes.bridge_name_num;
if (!testVals[zone]) {
testVals[zone] = true;
values.push({
//Create a ItemFileReadStore and use it for the
//ComboBox's data source
var dataItems = {
identifier: "name",
label: "name",
items: values
//console.log(dataItems);
var store = new Memory({
data: dataItems
//console.log(store);
this.mySelect.set("store", store);
exportReport: function(){
//this.results.innerHTML = "<center><b>Processing...</b><br><img src='widgets/tExport/images/loading.gif' width='360px'></center>"
var userEntry = this.mySelect.value;
//var message = new Message({
//message: userEntry,
//titleLabel: "userEntry"
this.gpSubmit(this.mySelect.value);
gpSubmit: function(userEntry){
this.gp = new Geoprocessor(myservice");
var params = {
"Bridge_Name": userEntry
console.log(params);
this.gp.submitJob(params, lang.hitch(this,this.jobComplete), this.jobStatus, lang.hitch(this, this.jobError));
jobComplete: function(jobInfo){
this.gp.getResultData(jobInfo.jobId, "pdf_export", lang.hitch(this, function(data){
console.log(data);
console.log(this.results);
this.results.innerHTML = "<a href='" + data.value.url + "'><div><img src='widgets/VegtExport/images/zip-icon.jpg' height='20px'>  <b>Export Package Ready!</b></div></a>";
console.log(jobInfo.jobStatus);
console.log(jobInfo.results);
jobStatus: function(jobInfo){
console.log(jobInfo);
jobError: function(error){
this.results.innerHTML = "<center><b>Export Failed...</b></center>";
At the moment the error I am getting is:
Uncaught TypeError: this.gp.submitJob is not a function
at Object.gpSubmit (Widget.js?wab_dv=2.6:131)
at Object.exportReport (Widget.js?wab_dv=2.6:120)
at HTMLDivElement.<anonymous> (init.js:63)
RobertScheitlin__GISP
ME,
   You are correct I had it backwards. You have your requires and there subsequent parameter names out of sequence:
define([
"jimu/BaseWidget",
"dojo/aspect",
'dojo/_base/html',
"dojo/query",
"esri/tasks/query",
"dojo/_base/array",
"dojo/on",
"dojo/_base/lang",
"dojo/dom",
'esri/request',
function (
declare,
BaseWidget,
aspect,
html,
ConfigManager,
WidgetManager,
FeatureLayer,
dojoQuery,
Query,
QueryTask,
Memory,
array,
on,
lang,
dom,
JobInfo,
esriRequest,
Geoprocessor,
GPMessage,
Message
Line 6 does not match line 31 and that throws all your other parameters out of line.
ME,
  Is your GP service synchronous or asynchronous? GP submit is only available for synchronous and execute is what you use for asynchronous.
MarkEastwood
The GP service is asynchronus. I thought GP Submit was meant for asynchronus services based on my reading here.
ME,
define([
"jimu/BaseWidget",
"dojo/aspect",
'dojo/_base/html',
"dojo/query",
"esri/tasks/query",
"dojo/_base/array",
"dojo/on",
"dojo/_base/lang",
"dojo/dom",
'esri/request',
function (
declare,
BaseWidget,
aspect,
html,
ConfigManager,
WidgetManager,
FeatureLayer,
dojoQuery,
Query,
QueryTask,
Memory,
array,
on,
lang,
dom,
JobInfo,
esriRequest,
Geoprocessor,
GPMessage,
Message
MarkEastwood
Ah, of course .... Thanks!
