Using pandas in ArcGIS pro
3984
6
10-23-2017 01:14 AM
YasunariMorita
I try to deal with table data by using pandas from ArcGIS pro.
But, I have mysterious error below.
Runtime error
File "<string>", line 1, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\__init__.py", line 25, in <module>
from pandas import hashtable, tslib, lib
File "pandas\tslib.pyx", line 5421, in init pandas.tslib (pandas\tslib.c:114996)
File "pandas\tslib.pyx", line 5338, in pandas.tslib.TimeRE.__init__ (pandas\tslib.c:85126)
File "pandas\tslib.pyx", line 5219, in pandas.tslib.LocaleTime.__init__ (pandas\tslib.c:82425)
File "pandas\tslib.pyx", line 5239, in pandas.tslib.LocaleTime.__calc_weekday (pandas\tslib.c:82859)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\calendar.py", line 79, in __getitem__
return funcs(self.format)
ValueError: embedded null byte
"null byte" probably means that some paths or file names include \0,but where?
And, this error happens only in case of python3.
any advice would be helpful.
Thanks in advance!
Tags (3)
DanPatterson_Retired
I suspect it might have something to do with the newer 'arcgis' module which uses pandas as a shell for the SpatialDataFrame.  If you examine the menu tree in windows, pandas is indeed installed.  Hence the reason I was asking where you are running python from.  When using Pro, you should be using python and everything from the required anaconda package distribution.
What is the nature of the table?  (type, field names, data types etc)
How are you accessing Pandas? (Pro script window, another IDE etc, a tool from within arctoolbox in Pro?)
can you convert/load the table within Pro without issue?
Any other useful details.
YasunariMorita
From Pro script window, I typed "import pandas as pd",then occurred the error.
I checked "import pandas as pd" in many way.
I try test.py script below.(execute command:propy.dat test.py)
import arcpy
import pandas as pd
ERROR
BUT,
import pandas as pd
import arcpy
SUCCESS!
Why import pandas after import arcpy???
ShaunWalbridge
Hello Yasunari,
Could you share what version of ArcGIS Pro you're using, and what version of Windows? Could you also run this from the Python prompt in Pro:
import locale, time
local.setlocale(local.LC_ALL, 'ja')
time.strftime('%a')
Does that produce the same error?
Shaun
YasunariMorita
Hi,Shaun,
version of ArcGIS Pro:1.4.1
version of Windows:windows 7 professional SP1 (64bit)
I ran your code, and it porduced the same error!
import locale, time
locale.setlocale(locale.LC_ALL, 'ja')
'ja'
time.strftime('%a')
Runtime error
I wish this was helpful for you.
ShaunWalbridge
Ah yes, thanks. Yes, this is a problem with the Windows C Runtime (UCRT) that is shipped with ArcGIS Pro 1.4 and earlier. We've fixed the problem in ArcGIS Pro 2.0, if you can upgrade.
Cheers, Shaun
