How can I open the tool "Share as Web Layer"
1754
5
10-17-2017 11:38 AM
HoriaTudosie
Using ArcGIS Pro 2.0(1) SDK, how can I initiate the command "Share as Web Layer" as I do from the popup menu on the layer from the content dialog:
Also, how can I pre-populate the parameters of the tool:
I need the user just to check and click Publish...
Tags (1)
KristianLarsen1
Any way to access this in 3.x?
GKmieliauskas
You can open "New WEB layer" using ID (esri_sharing_SharingAsWEBLayerCXMUBtn)
var commandId = "esri_sharing_SharingAsWEBLayerCXMUBtn";
IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper(commandId);
var command = wrapper as ICommand;
if ((command != null) && command.CanExecute(null))
  command.Execute(null);
Another way is to open geoprocessing tool dialog using Geoprocessing.OpenToolDialog
KristianLarsen1
Hi and thanks for the swift help!
I'm using the 3.2 SDK, and i can't get any of these to work.
Command is null, and OpenToolDialog returns "tool not found".
Is there any documentation available for the "esri_sharing_SharingAsWEBLayerCXMUBtn" command?
Right now i'm calling a share script from a py toolbox using Geoprocessing.ExecuteToolAsync, but i really don't want to rewrite the whole shareAsWebLayer dialog.. So the idea is to do some checks, filtering, metadata and database-stuff before passing the args to the shareAsWebLayer tool.
KristianLarsen1
ICommand.Execute didn't work because i had no selected layer, or the layer selected was not the correct type. Still it only opens the dialog, i guess it doesn't support args..
Some documentation for this would be nice.
AbhijeetNandeshwar1
Hello @GKmieliauskas ,
I tried this workflow it's not working. Also, How can I use Geoprocessing.OpenToolDialog() method because there is no geoprocessing tool present there for sharing as web layer.
private ICommand _cmdOpen;
public ICommand CmdOpen
get
return _cmdOpen ??= new RelayCommand(() =>
var wrapper = FrameworkApplication.GetPlugInWrapper(commandId);
if (command != null && command.CanExecute(null))
else
ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(
"Cannot execute 'Share As Web Layer' command in this context.");
Regards,
Abhijeet
