ArcGIS Enterprise 10.5 Backup
1192
10-17-2017 10:29 AM
Cesar_AugustoRodriguez
Hi! I'm trying to do a backup on the ArcGIS Enterprise, but when I execute the command
C:\>webgisdr --export --file C:\BACKUP\webgisdr.properties
I see the following error message "webgisdr" is not recognized as an internal or external command, program or executable batch file.
George_Thompson
Esri Notable Contributor
Did you follow this doc: Create an ArcGIS Enterprise backup—Portal for ArcGIS (10.5.x) | ArcGIS Enterprise ?
4. Open a command window on the Portal for ArcGIS machine, change the directory to the location of the webgisdr utility, and run the utility with the export option.
The default location of the webgisdr utility is C:\Program Files\Portal\tools\webgisdr.
--- George T.
George_Thompson
--- George T.
No, I did not, Thank You for your help, now I understand what was the error.
George_Thompson
Please mark the answer as correct for others to find
--- George T.
Thank you for your suggestion
