Adding Data to New Field
1725
5
10-17-2017 11:21 AM
DougHaller1
How do I populate a new field with a URL? I added a field to the attribute table.  I defined it as a string. I cannot seem to populate the field with any data, specifically a URL.  Is it possible that the length of the url exceeds the default charter length? Thanks in advance.
CarmelConnolly
Hi Doug,
When calculating string values in ArcGIS Online like URLs, you need to enclose them in single quotes like this:
Hope that works!
Carmel
CarmelConnolly
Hi Doug,
Can you go to the item details of the layer > Data > Click on the name of the field in question > Show Detailed View > and share a screenshot of the information here?
How are you attempting to edit the field?
Have you tried using a short URL like https://www.esri.com ?
Carmel
DougHaller1
Thanks Carmel...I am logged in with my developer account, I am working with a shapefile that is now  a hosted feature layer. When I open it as a map and select "Add Field" I can add a field but not populate the field with data, in this case a URL.  I tried using Field Calculator but that did not let me add a string to all the cells in the column.
CarmelConnolly
Hi Doug,
If you click on Edit on the toolbar > click on a feature > can you fill in attributes that way?
What message does the field calculator give you?
Carmel
DougHaller1
Hi Carmel, thanks...
I can use "Calculate" to add zeros to the new field.zerosurl But when I try to input a url, I receive an error message. See images.
CarmelConnolly
Hi Doug,
Hope that works!
Carmel
