Hello Ken Doman,
Thanks for your response.
I think I missed explaining my requirements clearly here. Let me explain it through use case scenarios. I am developing application for cement industry. User from cement industry will use the application for choosing appropriate location for their cement factory.
Application allows the user to pin point the potential location on the map where they intend to build cement factory. They can add multiple potential location at any single point of time for example say 10 locations. My application would pickup these locations and analyse and tell them if the potential location is appropriate to build cement factory.
I am trying to implement the application in the following way.
I would create a layer called Potential Site that would be linked through WFS to my WebAppBuilder Application and I would add Edit Widget to my application to allow them to add their potential location. The problem here is that multiple users can add their potential location at any given of time. The user should see only their potential locations. But If all users add locations using Edit Widget then they would be able to see other user potential locations also which I don't want to happen. I also want to add additional functionality that If user closes the browser than his added potential locations features should be deleted from layers.
I hope I am clearly able to explain my requirements to you.
Azghar
