Maximum Number of Attribute Fields in AGOL Feature Service?
2755
10-12-2017 10:15 AM
DanielKonzek
I have not been able to find the maximum number of attribute fields allowed in an AGOL feature Service.  Specifically, what is the max number of attribute fields for a related table in a feature service created using Survey123?
Thank you,
Dan
by Anonymous User
Not applicable
Hi Dan,
Currently the maximum number of attribute fields supported by Survey123 is 1024 for ArcGIS Online and 500 for Enterprise (Portal). This applies to the related tables (repeats) also.
This is documented here: Frequently asked questions—Survey123 for ArcGIS | ArcGIS
Regards,
Phil.
by Anonymous User
Not applicable
Hi Dan,
Regards,
Phil.
by Anonymous User
Not applicable
Hello @Anonymous User, is this limitation to the maximum amount of fields still relevant? I no longer see that stated on the documentation.
by Anonymous User
Not applicable
Hi @Anonymous User,
The limitation still exists, however as that post and link is quite old, it has moved in the online documentation. Also note this is a ArcGIS Online and Enterprise limitation, based on the database backend, so it is now documented in the ArcGIS Online/Enterprise documentation, which the Survey123 documentation links to:
https://doc.arcgis.com/en/survey123/faq/faqcreatesurveys.htm#ESRI_QUESTIONANSWER_9A8FFCAD83F9452F87FE87FC8C2DF7A6
https://doc.arcgis.com/en/survey123/desktop/create-surveys/troubleshootcreatesurveys.htm#ESRI_SECTION1_2815BD1DFB1B4D3398B37D960889C6CC
https://doc.arcgis.com/en/arcgis-online/reference/troubleshoot.htm#ESRI_QUESTIONANSWER_71B9FC50E40848FEB871DA0AA78587E0
Regards,
Phil.
