Inbox is it possible to have multiple over different Survey Forms.
937
10-10-2017 11:52 AM
RodLockie1
Hi
My question relates to the issue that i have in regards to inboxes.
I seem to be only be able to have one inbox available at all times for multiple surveys.
I can add one inbox but if i add another inbox (in a separate Survey) i remove the previous inbox records.
Is Survey123 designed for this type of interaction.
If so i believe this is kind interaction is backward in relation to the point of the inboxes. Specifically in regard to going to areas with limited connectivity where having multiple surveys for different type of buildings and equipment and having these preloaded on the device.
Rod
by Anonymous User
Not applicable
Hi Rod,
Currently it is not possible to load more than one Inbox for different surveys at a time with downloaded surveys. This enhancement is already logged in our system and I have added your comments to it.
Regards,
Phil.
