How do I name my Web Adaptor if using Java/Tomcat
1316
10-10-2017 12:08 PM
cemarcemar
I am wondering how to actually *name* a web adaptor (i want to change the default "arcgis" like say to http://server.localdomain/arcgisfoo/webadaptor) if i am using the Java/Tomcat version? In IIS it is a variable in the installation process but all the help docs and "discussions" I am not finding any answers for the Java version.
i am using version 10.4.1
thanks
RandallWilliams
When the web adaptor installs, it just extracts the files assocated with it. All you need to do is copy the arcgis.war and rename. Your application server (I'm coming from a Tomcat perspective) will extract the .war and create an application called whatever the .war is called. For instance:
cp /home/arcgis/arcgis/webadaptor/arcgis.war /app/apache_tomcat_location/webapps/portal.war
Basically, I copy arcgis.war twice to make portal.war and server.war, then copy those into the /webapps directory in Tomcat.
RandallWilliams
cemarcemar
Thank you so much!
