How to use Sketch graphics without changing the DataContext
822
10-09-2017 06:37 PM
RichardRolston
The "Sketch graphics on the map" example changes the DataContext to the SketchEditor.  I don't want to change the DataContext as controls on my window rely on a different DataContext.  How can I get around this?
Sketch graphics on the map—ArcGIS Runtime SDK for .NET Samples | ArcGIS for Developers
JoeHershman
The sample does this so they can bind the button commands directly to the SketchEditor commands.  There is no requirement that this approach is taken.  If you want to bind to the SketchEditor commands you can make a SketchEditor property in your ViewModel (DataContext) and bind through the property
-Joe
