Update Fields by Matching Fields
3867
9
10-10-2017 03:54 PM
DevinUnderwood2
I want to know what is the best way via arcpy  to update a feature field by referencing another features field.
I don't know if it is possible to use a updatecursor for 2 different features.
Would I just perform a temporary join and use arcpy like field calculator.
My Example of my cursor attempt.
searchcursor = arcpy.SearchCursor("BASE.ROADS_SG_ESC","","","","")
updatecursor = arcpy.UpdateCursor("escroads","","","","")
for row in searchcursor:
    RD20NAME = row.getValue("RD20NAME")
for row in updatecursor:
    if row.getValue("NAME")
        NAME = RD20NAME
       updatecursor.updateRow(row)
DanPatterson_Retired
you could join, then update a field... you could do this with cursors, but most people ignore simple field calculations can be accessed through the Calculate Field tool and its associated script code at the bottom
JoshuaBixby
MVP Esteemed Contributor
For starters, look into using the Data Access (What is the data access module?—Help | ArcGIS Desktop ) cursors instead of the original/old cursors.  The DA cursors perform much better and are a bit more Pythonic.
Your code snippet confuses me more than helps me understand what you are trying to do.  Code aside, what are you trying to do?
DevinUnderwood2
Thank you for the suggestions.
I will look  into the Data Access module as an alternative to old cursors.
Good advice on Calculate field tool and a join.
I will see what works for me. As I am trying to copy attributes from one field of a feature class to another feature class.
However, I need to match the feature classes fields that have different field names. All of this done via a python script.
CCWeedcontrol
Here is a code i use for similar situations.
You need to have a uniqueID for both features layers.
from time import strftime
print "Start script: " + strftime("%Y-%m-%d %H:%M:%S")
import arcpy
#Transfer of Multiple Field Values between Feature Classes where there is a 1:1 Match between Field Sets
sourceFC = "Parcels"
#change OID@ to your uniqueID
sourceFieldsList = ['OID@', 'Field_1','Field_2', 'Field_3','Field_4']  # Your Source fields
# Use list comprehension to build a dictionary from a da SearchCursor
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sourceFC, sourceFieldsList)}
updateFC = "Points"
updateFieldsList = ['OID@', 'Field1', 'Field2', 'Field3', 'Field4']  # your updateFC fields
with arcpy.da.UpdateCursor(updateFC, updateFieldsList) as updateRows:
    for updateRow in updateRows:
        # store the Join value of the row being updated in a keyValue variable
        keyValue = updateRow[0]
        # verify that the keyValue is in the Dictionary
        if keyValue in valueDict:
            # transfer the values stored under the keyValue from the dictionary to the updated fields.
            for n in range (1,len(sourceFieldsList)):
                updateRow = valueDict[keyValue][n-1]
            updateRows.updateRow(updateRow)
del valueDict
print "Finished script: " + strftime("%Y-%m-%d %H:%M:%S")
DevinUnderwood2
Thank you, I will try this out.  My unique will be roadsegid
DevinUnderwood2
This worked perfect. I only need to modify to only update features that have a RecID = 0
I used this and added code to generate a zipfile.
CCWeedcontrol
Can you post your modified code please.
DevinUnderwood2
I would like to post it after I modify the code some more to use ListFields rather than manually hardcode the field names.
Also, one last section of tying in the max() value to the auto increment () function, which I haven't had a chance to test yet, but soon.
ChadBunn1
Is it possible to modify this script so that a source field and an update field could have different field types if the values are the still the same?  For example if my source and update fields have a value of '1234', but the source field is an integer and the update field is a string, can they still be used with list comprehension somehow? Or would it be better to just add a corresponding field with the matching field type to my update layer?
