How do I get non-queried data points to drop off the map with Query tool?
1118
10-04-2017 02:36 PM
MelissaTraverso
Hi I would like to figure out how to get my data points that are not being queried to drop off the map when I use the widget. Does anyone know how to do this?
The filter widget has this feature but it doesn't have the zoom feature that the query widget has.
Melissa
Tags (1)
RobertScheitlin__GISP
Melissa,
  The only way to do this is to not have the data points as part of your web map. That way the query widgets results would be the way the data can be seen. The other thread you were commenting on about the filter widget will work for zooming to the filtered results but you need to start with a WAB Dev app and not a AGOL WAB app that has been minified.
