Map Title (map properties) not displaying as dynamic text in layout
1007
10-05-2017 09:36 AM
LynnKanieski1
In ArcGIS Pro 2.0.1, I'm using dynamic text for the title element in my layout, however my map title does not show up in the dynamic drop down menu.   When I go into my map properties, I can see the name of my map.   This worked earlier in a different layout that I created.  Am I missing something simple here?  Thanks.
KoryKramer
Esri Esteemed Contributor
Hi Lynn,
Do you only have 1 map in the Pro project?
Do you have a map frame added to the layout that references the map?  And just to confirm, if you look at the Map Properties for the map that is the same one referenced by the map frame in the layout, it has the name that you'd like to use for the title, correct?
What is it that you aren't seeing?  The title isn't populated for the "Name of Map" property in the Dynamic Text dropdown?
