AttributeError: 'GIS' object has no attribute 'admin'
13004
12
10-03-2017 01:36 PM
JamesGustine
Just starting to play around with the ArcGIS API for Python. I am stuck trying to call server submodule under the admin module. My install can't seem to find either. Just running thru this code on the reference page doesn't work for me.
from arcgis.gis import GIS
gis = GIS("https://portalname.domain.com/portal", "username")
gis_servers = gis.admin.servers.list()
print (gis_servers)
gis doesn't give me access to an admin property
Any clues as to where I am going wrong here would be awesome. Probably something super simple
but thanks in advance.
James
JoshuaBixby
MVP Esteemed Contributor
Double check which version of the API you are using.  The releases come fast enough that I have been tripped up by following the documentation when I forgot to upgrade to the latest version.
JoshuaBixby
My first thought is permissions.  What permissions does username have in Portal?
DanPatterson_Retired
JamesGustine
same one, different page, mine is the api reference section
JamesGustine
Its an admin account with full rights. Seems to be able to get to and manage portal stuff just can't get the servers. to note:
I'm connecting thru the web adaptor url and the servers are federated. I've tried putting in the FQ server name but that doesn't seem to make a difference.
Thanks.
JoshuaBixby
JamesGustine
That did it Josh. Had to run the update from conda
conda upgrade -c esri arcgis
I was trying to upgrade from the python package manager in Pro, but apparently that didn't do it.
Thanks again man.
by Anonymous User
Not applicable
Where does one enter this? I've tried entering it in the python window and get an "Invalid Syntax" message.
Thank you,
Randy McGregor
by Anonymous User
Not applicable
You run the command in Command Prompt (Windows) or Terminal (Mac/Linux) after activating the Conda environment that you are using.
