Find matching attributes
4525
14
10-03-2017 08:18 AM
2Quiker
I am trying to update the points selected features field "Verifi2" with "Match" or "No" based on if the 'SiteAddres' field of the selected feature matches the parcels layer 'SiteAddress' field. I currently have the following code but all of the selected features have "No" in the Verifi2 field. Which is not the case because some of the selected point features SiteAddres does match parcels SiteAddress. I would appreciate some help please.
import arcpy
from datetime import datetime as d
startTime = d.now()
fc1 = "AddresPointsTest"
fc2 = "TaxParcels1"
#set up cursors
cursor1 = arcpy.da.SearchCursor(fc1, ["SiteAddres", "Verifi2"])
cursor2 = arcpy.da.SearchCursor(fc2, ["SiteAddress"])
with arcpy.da.UpdateCursor(fc1, ["SiteAddres", "Verifi2"]) as cursor1:
     for row1 in cursor1:
          with arcpy.da.SearchCursor(fc2, ["SiteAddress"]) as cursor2:
               row2 = cursor2.next()
               #print row2
               row1[1] = "Match" if row1[0].lower() == row2[0].lower() else "No"
               #print row1[2]
               cursor1.updateRow(row1)
try:
    print '(Elapsed time: ' + str(d.now() - startTime)[:-3] + ')'
except Exception, e:
    # If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    print "Line %i" % tb.tb_lineno
    print e.message
MitchHolley1
Do these two datasets have a unique ID that links them together?  If so, you could create a dictionary with ID: Address pairs and use that to search the attribute table.  Nested cursors get tricky...
Just to clarify, are you looking for any Addresses in FC1 that are not in FC2?
2Quiker
Yes they do have a unique ID that links them together. I guess i didn't think this through all the way...hummm
So some parcels have an address point (separate layer) but some address points don't match the parcels(separate layer) site addresses i need to find the ones that match and don't match, but only of the selected features in ArcMap.
MitchHolley1
If you make your Python script able to be consumed with ArcMap (via Script Tool), then it will automatically accept a selection.
What you need to do is:
1.) Build a dictionary of ID: Address pairs
2.) Search feature attribute table for presence of Addresses
3.) Update field based on result from 2
This should get you started.
fc1 = r'complete_path_to_featureClass1'
fc2 = r'complete_path_to_featureClass2'
#build a dictionary of OBJECTID : Address pairs, change OID@ to your uniqueID
addDict = {row[0]:row[1] for row in arcpy.da.SearchCursor(fc1, ['OID@','SiteAddress'])}
#search through fc2 to see if addresses match based on OBJECTID value
#again, change OID@ to your uniqueID
with arcpy.da.UpdateCursor(fc2, ['OID@','SiteAddress','Verifi2']) as cursor:
    for row in cursor:
        if row[0] in addDict:
            if row[1] != addDict[row[0]]: #if the value associated with those ids do not match
                row[2] = 'No'
            else:
                row[2] = 'Match'
            cursor.updateRow(row)
del cursor
2Quiker
Hi Mitch.
thank you for the reply and help. I tried the code but i am getting the same results as before.
I select the points in Arcmap and run the code in ArcMap python window. All of the point features have 'No' in the Verifi2 filed.
on line 12 of your code should it be if row[1] != addDict[row[1]] since your comparing the SiteAddress and SiteAddres fields?
Here is the code i am working with.
import arcpy
startTime = d.now()
fc2 = "TaxParcels1"
#set up cursors
#addDict is for the taxparcels
addDict = {row[0]:row[1] for row in arcpy.da.SearchCursor(fc2, ['OID@','SiteAddress'])}
#UpdateCursor is for the address points
with arcpy.da.UpdateCursor(fc1, ['OID@','SiteAddres','Verifi2']) as cursor:
    for row in cursor:
                row[2] = 'No'
            else:
                row[2] = 'Match'
del cursor
try:
    print e.message
MitchHolley1
A couple things... do not run this code in the Python executable window inside of ArcMap.  Please make this tool a Script Tool.  It will be much easier to manage and deploy. Secondly, no... the addDict[row[0]] is correct because you're asking Python to compare the value of the dictionary associated with that ID.  Please research dictionaries and script tools.  You may want to print the keys and values of the dictionary to make sure it's built properly.
2Quiker
I tried your suggestion to put it into a script but i still just get "No" for all the features.
Would it have to do with the fact that the taxparcels address filed are all upper case letters and the points address field are all lower case?
MitchHolley1
Yes... the != operation is a strict comparison.  I would include .strip() and .lower() for comparison.
2Quiker
tired the following but i get following error:
if row[1].strip().lower() != addDict[row[0].strip().lower()]: #if the value associated with those ids do not match
AttributeError: 'int' object has no attribute 'strip'
if row[1].lower() != addDict[row[0].lower()]:
MitchHolley1
if row[1].strip().lower() != addDict[row[0]].strip().lower()
