Restricting user entry values between multiple entry questions
748
09-29-2017 03:48 PM
MelissaBlue1
I am looking to create a survey where I would like the user to be able to "spend" $10 in $1 increments on multiple options. In other words you have $10 to spend, how would you spend them towards obtaining the following:
1) Provide access to current open space (choice $0 to $10)
2) Create "pocket" or neighborhood parks within the city (choice $0 to $10)
3) Obtain new parcels to be dedicated as open space (choice $0 to $10)
The user can spend all $10 on one question or $4 on question 1) and $6 on question 3). I would like the form to keep track of what he/she has spent as they go through the choices and not allow them to use more than the allotted $10. It would be best if they had the ability to change their answers until they have the desired entries.
Is this possible to do and could you steer me on how I could accomplish this?
Many thanks.
Kevin Sato
Cottonwood Heights GIS
Cottonwood Heights, Utah
IsmaelChivite
Esri Notable Contributor
Hi.  A simple approach could be to simply show a visual warning to the user when the sum of the three questions is more than 10. This can be done using a note type of question and an expression in the relevant column.  You could also use a constraint to prevent that the form is submitted in case that the spending is overall greater than 10. The following screenshot illustrates how you could go about this.  Note I also use the spinner appearance, which I think will work very well here to facilitate incrementing and decrementing spending easily.
I am attaching the XLSFile below so you can import it into Connect.
