Delete multiple data
5399
5
09-29-2017 07:50 AM
JuliePoulin
Hi! I'm new to Survey123. I had create a survey and have add multiple data (100+). I know how to delete one record at a time. But how can we delete multiple data (50)?
Thanks!
BrandonArmstrong
Thank you for clarifying and providing the screenshot, Julie.
I was wondering if there are attachments that are included with these records?  If not, I would like to recommend reviewing the documentation outlining credit cost related to the storage of feature services (without attachments).  If interested, please click on the link below...
Credits by capability
I currently have a service with over 1,000,000 records (2 rows) which has a size of 145 MB.  That means, with current credit cost, it would be (145 MB/10 MB) * 2.4 credits = 34.8 credits per month
Understanding that you may still want to use the method of exporting your data, and deleting records as you go, I wanted to provide you with another link which outlines a process that can be taken to delete multiple records from a service at once.
FAQ: Is it possible to batch delete features in ArcGIS Online?
Please take caution when using these steps, as once the records are deleted, they will not be retrievable.
Brandon
BrandonArmstrong
Hello Julie,
Can you please elaborate on 'adding multiple data' to the survey?  Does this mean that there have been multiple surveys that you have submitted and are now looking to delete them?
If so, there are a few methods which can be used to accomplish the task.  Please confirm or further explain the questions listed above.
Brandon
JuliePoulin
Hi Brandon,
Sorry for being unclear.
In a survey, i had record multiple points (surveyPoint). I don't want to use many "Esri credits", so I want to download (SHP) them and delete them each day.
I know we can delete one surveyPoint at a time. But can we all delete them in one click?
Did I need to create a new survey (copy/paste) each day and delete the "old" one.
Thanks!
BrandonArmstrong
Brandon
JuliePoulin
Thank you Brandon for your answer!
I had follow the steps of the FAQ and it works!
Thanks again
NR-DonCoppleGISS
I don't think this is the best solution and would make the recommendation to allow multiple deletion in the application.  Place check marks to select several and delete.  I don't even see the object IDs of my data, and selecting one at a time is not a great option.  I like the surveys, just need the option to delete a previous year's data after downloading it.
