Cannot access items array property of MapView.allLayerViews (ArcJS API 4.4)
1989
09-25-2017 03:47 PM
DevonCanady
See below:
require(["esri/Map","esri/views/MapView"], function(Map, MapView) {
   var map = new Map({ basemap: "streets" });
   var view = new MapView({
      container: "viewDiv",
      map: map,
      center: [-97.744483, 30.272705],
      zoom: 15,
console.log(view.allLayerViews.items);
console.log(view.allLayerViews.items[0]);
console.log(view.allLayerViews.length);
I suppose the array calls are accessing the Array prototype, but I don't know how to make it not do that. I would like to be able to loop through the layerViews with forEach().
KenBuja
MVP Esteemed Contributor
You have to wait until you've added something to the view and it's ready. This is taken from this sample (adding lines 106-110)
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Get started with layers - 4.4</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.4/esri/css/main.css">
  <script src="https://js.arcgis.com/4.4/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #layerToggle {
      top: 20px;
      right: 20px;
      position: absolute;
      z-index: 99;
      background-color: white;
      border-radius: 8px;
      padding: 10px;
      opacity: 0.75;
  </style>
  <script>
    require([
        "esri/Map",
        "esri/views/SceneView",
        "esri/layers/TileLayer",
        "dojo/dom",
        "dojo/on",
        "dojo/domReady!"
      function(
        Map, SceneView, TileLayer, dom, on
         * Create two TileLayer instances. One pointing to a
         * cached map service depicting U.S. male population and the other
         * pointing to a layer of roads and highways.
        var transportationLyr = new TileLayer({
          url: "https://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Transportation/MapServer",
          // This property can be used to uniquely identify the layer
          visible: false
        var housingLyr = new TileLayer({
          url: "https://tiles.arcgis.com/tiles/nGt4QxSblgDfeJn9/arcgis/rest/services/New_York_Housing_Density/MapSer...",
          opacity: 0.9
         * Layers may be added to the map in the map's constructor
        var map = new Map({
          basemap: "oceans",
          layers: [housingLyr]
         * Or they may be added to the map using map.add()
        map.add(transportationLyr);
        var view = new SceneView({
          map: map
         * The map handles the layers' data while the view and layer views
         * take care of renderering the layers
        view.on("layerview-create", function(event) {
          if (event.layer.id === "ny-housing") {
            // Explore the properties of the population layer's layer view here
            console.log("LayerView for male population created!", event.layerView);
          if (event.layer.id === "streets") {
            // Explore the properties of the transportation layer's layer view here
            console.log("LayerView for streets created!", event.layerView);
         * Layers are promises that resolve when loaded, or when all their
         * properties may be accessed. Once the population layer has loaded,
         * the view will animate to it's initial extent.
        view.then(function() {
          housingLyr.then(function() {
            view.goTo(housingLyr.fullExtent);
            for (var i = 0; i < view.allLayerViews.length; i++) {
              console.log(view.allLayerViews.items[i].declaredClass);
        var streetsLyrToggle = dom.byId("streetsLyr");
         * The visible property on the layer can be used to toggle the
         * layer's visibility in the view. When the visibility is turned off
         * the layer is still part of the map, which means you can access
         * its properties and perform analysis even though it isn't visible.
        on(streetsLyrToggle, "change", function() {
          transportationLyr.visible = streetsLyrToggle.checked;
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <span id="layerToggle">
    <input type="checkbox" id="streetsLyr"> Transportation
  </span>
</body>
</html>
RobertScheitlin__GISP
Devon,
   Based on you shared code you only have a basemap added to the view and no other layers so the allLayerViews collection would be empty.
KenBuja
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #layerToggle {
      top: 20px;
      right: 20px;
      position: absolute;
      z-index: 99;
      border-radius: 8px;
      padding: 10px;
      opacity: 0.75;
  </style>
  <script>
    require([
        "esri/Map",
        "dojo/dom",
        "dojo/on",
        "dojo/domReady!"
      function(
          visible: false
          opacity: 0.9
        var map = new Map({
          basemap: "oceans",
          map: map
  </script>
</head>
<body>
  </span>
</body>
</html>
DevonCanady
I tried to only include the pertinent code since it's a snippet of a larger file but I failed to include the lines where I added my layers to the map. But Ken you are correct. Embedding the layer.then() inside the view.then() allows me to access the items array of view.allLayerViews. Thanks!
