GP Service Ideas to output a .json file
1674
09-21-2017 07:23 AM
JamesCrandall
EDIT: Turns out the .py script example I have below does actually create the .json file with the input parameter value.  I'm just not correctly handling the JavaScript side to allow user to "SaveAs".
Wild idea but *should be* straight forward.  I'd like to publish a GP service that simply takes an input string (well formatted json), write that string to a .json file (just a text file would do with a .json extension I think) and set this to an output parameter.
What I have so far doesn't error out but also doesn't seem to generate the output .json I'm expecting.
Simple python script source to the GP tool:
import os
import arcpy
import uuid
#GP tool input parameter
inSessionStr = arcpy.GetParameterAsText(0)
#write a to a temp .json file (taken from the enhanced print service blog
output = 'SessionFile_{}.{}'.format(str(uuid.uuid1()), "json")
Output_File = os.path.join(arcpy.env.scratchFolder, output)
#write to the .json file
outputSessionfile = open(Output_File, 'w')
outputSessionfile.write(inSessionStr)
#specify the output parameter as the outputSession file
arcpy.SetParameter(1, outputSessionfile)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Any ideas on if this might work and what to look for?
JamesCrandall
Again, the python script works as intended and I just wanted to post the full solution.
GP Tool Source Script:
import os
import arcpy
import uuid
What the GP Tool looks like:
Parameters:
inputSession: String
returnFile: File
JavaScript implemented in a widget:
executeGPDownloadFile: function (param) {
             var gp = new Geoprocessor("https://mydomain/myserver/rest/services/GPToolName/GPServer/GPTaskName");
             var params = { "inputSession": param };
             gp.execute(params, downloadFile);
             function downloadFile(results, messages) {
                 //do something with the results
                 var theSessionFile = results[0].value;
                 window.open(results[0].value.url);
JamesCrandall
import os
import arcpy
import uuid
Parameters:
returnFile: File
