How to modify/emulate the new 'predominate value' expression in the "Clustering" pop-up on AGO?
1507
09-22-2017 10:47 AM
ChrisRobertson2
In the recent ArcGIS Online update the ability to cluster points was added. There is also a new cluster pop-up that includes a default 'predominate value' expression. Since i don't have a lot of experience with Arcade I am looking for some help to create similar Arcade expressions for other fields. In the screenshot below you can see that the default expression is the predominate [County] of the clustered points. I would like it to show the predominate [Name] of the clustered points. Since these are string variables I'm not sure how to get this value in Arcade. It doesn't appear that you can edit the default expression. I am guessing if this functionality is even possible, I would have to create it in the attribute expressions window. Any ideas?
Edit: I just wanted to add that after some research it looks like the 'predominate value' is based upon the field the features are symbolized by (in my case by [county]). From what I have tried so far it looks like the ability to add more fields/expressions to the cluster pop-up isn't possible. I could re-symbolize by the [name] field and that would cause the default expression to change. I however would like to keep the features symbolized by county so this doesn't solve my problem. Essentially I have a feeling this ability is not possible in this version of AGO.
MikeMinami
Esri Notable Contributor
There's nothing more available at this time, but we do want to give you access to attributes of all features within a cluster, so you could calculate your own stats. So we'll be working on it.
Mike
MikeMinami
Mike
