How to transform images (Flip and Rotate) using Python?
2284
5
09-08-2017 01:43 AM
PeterWilson
I have received imagery from a surveyor that is currently falling within the Northern Hemisphere and upside down. The following is easy to resolve if its a CAD drawing using the "Transformations" tab under the properties window of the CAD layer within ArcMap. Is there a way to apply the same transformation using Python for each image tile?
CAD: Transformation
Original Position: Northern Hemisphere and rotated.
CAD: Transformation and Rotation
CAD: Transformed (correct location)
Imagery: Current Imagery (Northern hemisphere and rotated)
Any assistance to achieve the following will be appreciated.
RichardGeoghegan2
You could try use the third party 'Pillow' python module.
This should allow you to rotate multiple images at once.
JayantaPoddar
Have you tried Flip—Help | ArcGIS Desktop ?
Think Location
DanPatterson_Retired
I bet you don't have world files for the images... Sounds like a missing negative sign and a flop of the X and Y coordinates...  World files would be a lot faster to fix
RebeccaStrauch__GISP
I agree with Dan, and would first take a look at the world file first in case a negative sign is missing or reversed.
Some links that might help:
If the world file doesn't work, then I would look into the flip...but make sure you know what the input world file and/or spatial reference is, so you can figure out what you need to correct it.  You can usually find out this info in ArcCatalog with are right-click to look at the properties.
(I don't have any experience with the "pillow" python mod...but I plan to check it out too).
RichardGeoghegan2
PeterWilson
Hi Richard
Thanks I clean forgot about Python's Pillow module. I was able to batch all the images and correct them.
